Nav System Stereo WIring
2615 Views 4 Replies 4 Participants Last post by  PDXEvo
I installed a bluetooth system on my car today, and I had to figure out what wires did what. Turns out, if you have the 9 speaker Fosgate system, you will need to jack into the sound wires on the amp, which is located under the drivers seat. I mapped out what all the cables are, since I couldnt seem to find this anywhere, so I am sharing here to save you guys some time in the future.
NAV Unit:
***These wires are low voltage outputs for the amp***
Front Left Speaker + WHITE
Front Left Speaker - BLACK
Front Right Speaker + RED
Front Right Speaker - GREEN
Amplifier under Driver Seat:
Battery Positive + RED (pins 25, 35, 36)
Ground - BLACK (pins 24, 31, 32)
Front Left Speaker + White/Blue pin 28
Front Left Speaker - Black/Yellow pin 38
Front Left Tweeter + White/Blue pin 6
Front Left Tweeter - Black/Yellow pin 14
Front Right Speaker + White/Red pin 27
Front Right Speaker - Black/Red pin 37
Front Right Tweeter + White/Red pin 5
Front Right Tweeter - Black/Red pin 13
Rear Left Speaker + Yellow/Blue pin 1
Rear Left Speaker - Gray/Blue pin 7
Rear Right Speaker + Yellow/Red pin 2
Rear Right Speaker - Gray/Red pin 8
Subwoofer coil #1 + Gray
Subwoofer coil #1 - Yellow
Subwoofer coil #2 + Blue
Subwoofer coil #2 - White
1 - 5 of 5 Posts
Subwoofer Details
For those interested, the subwoofer is dual 1.1 ohms.
if you read it over, you have no rear right but you got 2 of each front left tweeters
Thats because they all use the same color like that. You will know which is which by taking a AA battery and touching the POS and NEG terminals to the battery. You will hear the correct speaker fuzz. Ill add the pin numbers, maybe that will make it easier.
1 - 5 of 5 Posts
