I’ve kinda gone crazy trying to figure it out. I’ve replaced the upstream o2 sensor, replaced the wideband sensor and bought a new aem digital gauge. I checked the exhaust around the downpipe near the sensor and see no exhaust leaks. I ohm'd out the coil packs and injectors, I replaced one coil pack. Replaced the spark plugs. I had the injectors cleaned and flow tested. I’ve used electrical cleaner on the MAF, MAP and IAT sensors. I installed a fuel pressure gauge (fuel pressure is consistent). I’ve swapped around the fuel injector and fuel pump relays, I even tried a friends MFI relay. I just resoldered the injector pigtails, I figured it wasn’t this but did it again anyway. I did a boost leak test, it’s the first time I’ve done it but I couldn’t find any leaks.
The car ran great and had been through multiple tanks of gas and then one day cruising on the highway I saw the AFRs spike lean and kinda stayed there. I drove it home as it felt mostly okay but misfiring a little. That’s when I changed the plugs and coil pack it Seemed slightly better but AFRs were still bouncing everywhere. Once day cruising around town it would stall at the stop lights and had to keep my foot on the gas a little, wouldn’t idle. I got home and that’s when I replaced the o2 sensor, wideband and did the injectors. I also found one of the bolts loose on the manifold to turbo. Since then It runs but the AFRs are still bouncing everywhere and when turning on the AC it wants to stall.
The thing that kinda confuses me is that the fuel trims while logging say they are happy and are within +-3% but I can watch the gauge and see it jumping everywhere. I know the tune is fine because I haven’t changed anything and have been through several tanks and like I said this started just cruising on the highway. Kinda at a dead end here with ideas. The last thing I can think to do is a smoke test and maybe a leak down test. Any help would be much appreciated
