There are a few things that could potentially be causing your issues with the AEM 25-302BK Fuel Pressure Regulator (FPR):
1. Incorrect Installation: It's possible that the FPR may not be installed correctly. Check to ensure it is installed according to the instructions provided with the regulator and that all connections and fittings are secure.
2. Faulty FPR: It's somewhat rare, but you may have received another faulty regulator. This could be checked by installing a different regulator and observing if the issue persists.
3. Issues with Fuel Pump: If your fuel pump isn't able to provide adequate pressure, the regulator may not be able to increase pressure correctly. Ensure your fuel pump is working properly.
4. Blocked or Leaking Lines: If the lines going to or from the regulator are blocked or leaking, this could cause issues with pressure regulation.
If you've gone through all these possibilities and are still experiencing issues, it might be best to consult with a professional mechanic or a specialist in fuel systems. They can better diagnose the issue through hands-on inspection and testing.
