Need your help guys and gals!!!!
1256 Views 7 Replies 4 Participants Last post by  white snuggie
So I'm probably just stupid, but I bought the depo racing fmic. And the lower side is 3". My issue, I have stock licp. Currently I have a garbage spectre 3-2.5 boot on it. But I want to buy new licp. My question, will anything work here. Or do I have to buy 3" licp.
1 - 8 of 8 Posts
Don't just view. Answer
If you are reusing stock lower intercooler pipe you need to buy a reducer coupler from autozone. If you are running 3 inch lower intercooler pipe then it should bolt on.
The reducer coupler size u need is 3-2.375 i think 2.5 is too big and will likely cause leaks during high boost condition.
Thanks. I think I'm going to buy the cobb hard lower pipe.
Just get the Depo LICP. I'm running it, couldn't be happier
Are you planing to run the intercooler with OTS map or protune?
I personally tested with stage 3 OTS map it performed real well ( 1 to 2 Knock highest), but the HP/TQ gains are from a real protune.
depo licp is 3 inch. should just get that.
i had planned on getting the depo, but theyre sold out for another month. so i said F*%& it and bought the cobb one piece licp. and ill just put a reducer on it. thanks for all your help guys.
1 - 8 of 8 Posts
