1 - 20 of 21 Posts
I just put in a Spec 3+ and now... well, it's strange. I push the clutch in all the way and try to put it in gear. It's incredibly difficult and the clutch is definitely engaging a bit when I'm putting it in gear (with the clutch pedal down). To put the car in reverse I have to force it into first, then I can force it into reverse.
Anyway the new clutch has less than 100 miles.
Anyone with a new clutch experience this before? Or have any ideas as to what needs to be done? I'll be checking the shifter cable later on.
Administrator
^What these guys said.
Chances are if you haven't already upgraded your CMC, your stocker is broken and leaking.
[Drag Racing Mod], [Sales Mod], [Local Team Member
ummm this is weird, change your cmc or bleed it properly. If this continue to happen, check your pressure plate.
my theory on those clips is that they serve no real purpose once the clutch is installed.
As far as the problem itself, it would have to be the a hydraulic issue OR maybe it's just that the clutch is so new that there's not much extra clearance even when it's completely disengaged.
Is you fluid level stable or has it dropped at all while driving?
Those are TORQUE DRIVE STRAPS, they serve a couple of purposes.
1) They help aid with distribution of torque
2) They move the pressure ring back when the clutch is disengaged
If these are damaged or missing the clutch will have issues disengaging
What purpose do these spring clips serve?
Looks like it might be number 2 more than number, since the picture on the link you gave only has number 2. any idea what number 1's purpose is specifically?
Soooo... A little birdie told me you might have a pressure plate issue. care to elaborate?
1 - 20 of 21 Posts
