Hello guys..
I'm new in this EVO X forums. so I have EVO X GSR 2009
MOD
stock motor
stock turbo
Greddy TCI Exhaust turbo back
turbo smart BOV
turbo smart e-boost street 40PSi
Agency Power cold Air intake
Agency Power intercooler
Cobb accessPort
93 octane
stage 5 fly wheel ,and stage 5 clutch
My problem is the car is not tune yet,, only the tuner setup the boost control
P1 12PSi P2 16PSi
so before 3days ago I got the Cobb accessport. and try to install it,, so the car install it,, and I ESc the code.. any why I tried to to tune my car and add some boost by learning from youtube in the Turbo smart channel ... so I think I do something wrong
mg: by setting not right setting.. OBS before it was 18PSI I made it 24PSI... so the car not working very well :wallbash: ,, 7000Rm only 10 PSI open..:confused2:
I need some body help me to tune the car ,, by telling me what I have to do?
qst1: Which stage i'm now,,what map should I go in this page to download
http://www.accessecu.com/accessport/mitsubishi/AP-MIT-002/EVOXIntMaps.html
Qst 2: to Set the boost level ,, Gate Pressure Setting..and over boost level
I email cobbtuning . then I got reply from Ian told me to go for the
Stage2+SF 93 Octane Stage2 with COBB SF Intake, using 93 Octane fuel. Requires turbo-back exhaust. +28% HP / +19% lb. ft. May require boost control system changes
then I download the map and try to setup in the Asseccport and then I got
MSG " the Map download not match with the car ,,are you sure you want copy it in Cobb asseccport ?
then I press yes but when I plug the cable to connect to the car .. it show gray font car is locked ...
I try to download other map same MSG I got every time ,,, I make sure It's EVO X 2009 GSR but AccessPort manger still :confused2:
waiting for your reply guys thx
MOD
stock motor
stock turbo
turbo smart BOV
Cobb accessPort
93 octane
P1 12PSi P2 16PSi
