Assuming this will work with a 2009 Lancer ralliart too?
Awesome work!
Awesome work!
I can't run on windows 11. The error already mentioned above appears, but Tactrix Open Port 2.0 and Drivers work normally. The error is "The code execution cannot proceed because op20pt32.dll was not found. Reinstalling the program may fix this problem."When I try to install it, it says
Greetings, any luck with this error?Same! I even did a read through ECU Flash first to make sure that's not causing it.
