1 - 7 of 7 Posts
Hello All.
As a lock down project, I have written a new piece of software that is useful for Evo X owners !
The new program is called "EVO X TOOLBOX" and allows you to do do the following...
1) Read All ECU's codes (Work in progress).
2) Clear codes (Work in progress).
3) Read steering wheel position sensor data.
4) Read timing chain stretch and limits.
5) Reset timing chain learning data.
6) Force test AYC/ACD pump to run.
7) ACD bleeding.
8) AYC Left side bleeding.
9) AYC Right side bleeding.
10) ABS sensors live data reading (Work in progress).
11) ABS solenoids drive test. (Work in progress).
12) Heating and Air Con. Live data read (Work in progress).
13) Heating and Air Con. actuators test (Work in progress).
NOTE: The ACD/AYC functions do NOT require the engine running or the steering wheel to be turned to activate functions.
You can simply activate the test and do the bleeding.
The test will stop after 5 minutes but you must make sure you don't run out of oil in the rear tank !
As you can see from above list, some features are still work in progress.
This software is PC only and needs you to have a Tactrix cable or other equivalent "PASSTHRU" cable.
This will work on any version of windows that supports the type of "Passthru" cable you have.
At the moment, I am looking for people that are willing to try it and give me some feedback on its operation and maybe some suggestions for other features.
I have fully tested this on my own car but this tool simply emulates how a MUT3 factory tool would do the same things.
Requirements and use....
1) Will run on any PC running windows XP / 7 / 8 / 10.
2) You will need to have installed a Tactrix interface or other "PASSTHRU" equivalent device previously.
If you have already installed and used EcuFlash, EvoScan or ETACS Decoder then you have already done this.
3) Download the file using the link at the end of this post and copy to a new folder.
This program does not require any further installs of any libraries or rely upon any other frameworks.
4) Windows may complain this file is a security risk but it is perfectly safe to download.
You may virus scan it before you run it if you need to.
Most virus programs scan files before they run anyway.
5) It is important that for ONLY the first time the program is run, the PC that will be used for doing the actual work will need an internet connection to activate and install a security certificate. After that, it does not need an internet connection again.
6) This program does NOT collect any personal information at any time nor does it contain any adverts or payment requests.
7) The software is absolutely free to use but remains copyright of myself.
8) Please post on here how you get on with it.
Download link....
Evoxtoolbox.exe
Any suggestions/comments etc... feel free to ask me :)
Wow. This is awesome. I'm downloading now for future use.. I don't have a Tactrix yet. But I'll grab one and try this out.
When I try to install it, it says
"The code execution cannot proceed because op20pt32.dll was not found. Reinstalling the program may fix this problem."
HELL TO THE YES ILL TRY IT!!! Especially for a fellow coder I’ll definitely give it a try once I pick up my X Tuesday!
Discussion Starter #6
You haven't installed a Tactrix interface yet !
1 - 7 of 7 Posts
