1 - 3 of 3 Posts
Hi everyone
please I need your help! I took my car into a Mitsubishi dealer because it had a noise when the clutch was out in neutral, I got them to take out the gearbox an at the same time got a brand new heavy duty clutch put it and flywheel skimmed. I got them to change the spigot bearing and throw out bearing. I just picked it up and the noise is still there! Anyone know what it could be or if it鈥檚 normal? Any help would be much appreciated 馃槉
Change your transmission oil. See how much metal flake comes out in the oil. If it's a lot, you'll know it's time for a rebuild.
Clutch out means the input shaft is spinning on the trans and it could be in the gearbox. Clutch in noise is going to be clutch related.
1 - 3 of 3 Posts
