change out ps fluid to atf instead of that crap mitsu stuff- if the noise goes away then it was the ps pump. If not then look at the plastic idlers.
easiest way to narrow it down.
That was the plan, just in reverse. I already have a new belt and pulleys for the next major service, so i was gonna do those first since i have to do them anyway. Then replace the PS fluid if the noise doesn't disappear.change out ps fluid to atf instead of that crap mitsu stuff- if the noise goes away then it was the ps pump. If not then look at the plastic idlers.
They market it as oem fluid that has to be run or else .That was the plan, just in reverse. I already have a new belt and pulleys for the next major service, so i was gonna do those first since i have to do them anyway. Then replace the PS fluid if the noise doesn't disappear.
What makes the Mitsu stuff crap?
OK. Ill look into it. You didnt really answer my question though...The mitsu fluid might just be ATF.They market it as oem fluid that has to be run or else .
ATF lubricates everything better, it was designed as a high pressure hydraulic fluid. and its way cheaper
I use ATF F - and yes, mitsu fluid is atf as well. no clue on viscosity,OK. Ill look into it. You didnt really answer my question though...The mitsu fluid might just be ATF.
Have you replaced yours? Is the ATF viscosity higher than the OEM fluid?
Its not oil pump. Recently changed the oil with no difference in sound. I'll be replacing the idler pulleys and belt as soon as a get a couple free hours. I'll check back in when complete.That seems like common Oil pump noise - get's louder when oil get's older, after oil change it's somewhat better but goes back to same noise level once oil get's older again.
My dealership said it's designed that way :/ I have 40k miles - noise was since day 1 and didn't change much.
Same here. Less miles but same experience.That seems like common Oil pump noise - get's louder when oil get's older, after oil change it's somewhat better but goes back to same noise level once oil get's older again.
