1 - 16 of 16 Posts
Thanks to driving back & forth to the dealership I have my car "broken in."
I was testing 0-60 in the car and I came up with almost 6 seconds in normal mode and 5.1 in super sport. This is with my gf using an iPhone to clock it so it's not that accurate. I was wondering what a normal time is? I kept the car in auto since I've heard the car knows when to shift better then me. :p
· Premium Member
Use evoscan and it will give you accurate numbers. If you don't have the tactrix cable, ask a fellow member in your area to lend you one.
unless you gf is a 100lbs get her out of the car and you can gain another .1-.2 sec..
From what I heard the '11s were/are capable of around 4.3 stock. This is in SS, off/off, launch control.
Where did you hear that? Last magazine that had the fastest 1/4 and. 0-60 tested a gsr that put down 13s flat and 4.3-4.4 0-60 and that was a gsr not an mr, mrs are slower 0-60 because they are programmed to save the sst.
^^ 1st gear is torque limited on the MR.
1 - 16 of 16 Posts
