1 - 4 of 4 Posts
Filed under: Tuners, Sports/GTs, Euro, Supercars, Ferrari
Click above for a high-res gallery of the Novitec Rosso F430 RACE
Novitec Rosso is good at making fast things even faster. Such has been the case with its twin-supercharged Ferrari F430s, which pretty much go like stink. Now, with the introduction of the Novitec Rosso F430 RACE, it would appear that any remaining deodorant has worn off. What's faster than going like stink? Going like stench? So be it. That's what this striped rocketship does.
The boost is dialed up on the dual blowers, which are also fitted with larger turbine vanes. Further engine, intake and exhaust tuning bump the car's output to 707 horsepower and 525 lb-ft of torque. Zero to sixty takes merely 3.5 seconds, and this stallion doesn't stop running until the speedo touches 216 miles per hour. Naturally, the suspension, brakes, aerodynamics and overall appearance are also given the once-over. After all, this is a super tuner car, and it needs to look and act the part. The customized interior features details like longer shift paddles, and the updated bodywork is set off with darkened lenses and the triple stripes. Bigger wheels and brakes sit at each corner, and an even bigger check is required if you want to take one home -- plan on writing it for a minimum of €193,277. How creative you get with Novitec Rosso's generally limitless set of options will determine just how much higher it'll be. Full details are in Novitec's press release after the jump.
Gallery: Novitec Rosso F430 RACE
[Source: Novitec Rosso]Continue reading Novitec Rosso F430 RACE gets in your face
More...
Thats smoking HOT! 707 HP!!
*gulp* minimum of €193,277
1 - 4 of 4 Posts
