Bought this car used and everything on it as far as I know is stock except for the brakes which I've redone and the sound system. I have the clutch replaced immediately upon buying it because the last person burnt it out of existence. We're talkin like this thing had ash coming off of one side and on the concave side of the flywheel there was three different 2 inch wide heat spots on there and all the teeth for pretty much ground out of existence. The guy drove this thing like he was learning to drive clutch. Got that fixed and now I have a new issue and I don't know what it is.
I start accelerating it revs up by a 1000~ RPMs drops off and then accelerates. No I'm not flooring it. I went as far as to drive the gas pedal with a stick (yes from a tree) to make sure that I had the same pressure. I think in the video I pushed it about an inch while in 5th. Also happens in other gears.
Video is uploaded to discord.
2014 Mitsubishi Lancer GSR
