I'm never ordering anything from Kansai again. It has been since July that I ordered my tow hook from them and still no word yet. Sean is doing his best but he can't make Kansai work any faster. Like I said, I'll never order anything from Kansai again.
what other option is there? other than getting the JDM crash beam
Yes, some groups will require you to have a visible, installed tow hook to run with them at the track. Most do not and only ask that you put it on if you have one. The reason for this is so they can quickly get you off the track if you go off, so the rest of the day can continue. Unfortunately our cars do not have one in the front, only in the rear. Custom work needs to be done to mount a towhook through the fake towhook hole in the front of our cars.do some tracks require that you have an aftermarket tow hook? or a certain placement/visibility of tow hooks?
ie, what are the functional benefits/need for a tow hook?
If you check out my recent laguna seca video, it was taken with a gopro mounted to my rennline towhook.Trying to get some inspiration With Go pro mount on a tow hook![]()
great more :$: to get myself track ready, I guess I'll look into which groups require it and see if I can get away without one for a bit. I understand the reasons why a track would require a functional tow hook and the install process based on threads on here.Yes, some groups will require you to have a visible, installed tow hook to run with them at the track. Most do not and only ask that you put it on if you have one. The reason for this is so they can quickly get you off the track if you go off, so the rest of the day can continue. Unfortunately our cars do not have one in the front, only in the rear. Custom work needs to be done to mount a towhook through the fake towhook hole in the front of our cars.
