Status
Not open for further replies.
1 - 1 of 1 Posts
Ok guys, this is a list of all TSB's and recalls. Im human so I may have missed some. If you see some that are not on this list please feel free to PM me and I will update as needed.
TSB Number (Issue Date) - TSB Title
08-00-002 (01/08) - X New Model Service Information (techtrain)
08-13-006 (03/08) - ECM REPROGRAMMING FOR DTC P1320 (techtrain)
08-13-006REV (??/08) - ECM REPROGRAMMING FOR DTC P1320 (techtrain)
08-13-006REVII (??/08) - ECM REPROGRAMMING FOR DTC P1320 (techtrain)
08-13-011 (05/08) - Engine Controls - Slight Hesitation When Accelerating (techtrain)
08-21-001 (??/08) - CAUTIONARY INSTRUCTION FOR HANDLING CLUTCH INTERLOCK SWITCHES - SMR (techtrain)
08-31-001 (??/08) - TPMS Sensor Service (techtrain)
08-35-001 (??/08) - Cautionary Instruction for handling Stop Light Switches - SMR (techtrain)
08-42B-003 (05/08) - Body - Revised Welding Points For Fender Shield (techtrain)
08-42A-008 (05/08) - Antenna - Revised Description For DTC B240A/B240B (techtrain)
09-42A-004 (04/09) - Rattle from Doors. Loose Window Bolts - 08-09 Lancer, EVO X, SPORTBACK
08-22-002 (06/08) - A/T - W6DGA Twin Clutch Transmission Characteristics (techtrain?)
08-33-001 (06/08) - Suspension - Revised Control Arm Securing Procedure (techtrain?)
08-42A-008 (??/08) - Corrected procedures for DTCS B240a & B240b - SMR (techtrain)
08-42A-012 (07/08) - Body Controls - DTC B240E Correction (techtrain)
08-42A-013 (07/08) - Keyless Entry/Starting - F.A.S.T. Key Feature Inop. (techtrain?)
08-51-001 (07/08) - Body - Revised Moulding/Garnish Removal/Installation (techtrain?)
08-22-003 (07/08) - Engine Controls - Coding Precaution Manual Revision (techtrain?)
08-52B-002 (07/08) - Alignment procedure for clock spring neutral point - SMR (techtrain?)
Recalls
April 2009 - Hood latch recall (http://www.tsbsearch.com/2008/Mitsubishi/Lancer+EVO/2)
September 2009 - Fuel Rail (url)
November 2009 - SRS Sensors (http://www.evoxforums.com/forums/showthread.php?t=22771&highlight=recall)
October 2013 - CMC Recall (http://www.evoxforums.com/forums/showthread.php?t=165098)
Service Campaigns
September 2009 - AWC Control Unit Reflash (url)
1 - 1 of 1 Posts
Status
