1 - 1 of 1 Posts
Vendor
Add a nice carbon fiber touch to your Mitsubishi Evo while saving weight and improving its aerodynamics with the Seibon Carbon Fiber Rear Diffuser! This product is a perfect upgrade for your Mitsubishi Evo that creates a more modern exquisite, and aggressive look. Plus, it will also enhance your car's aerodynamics allowing it to operate at peak performance.
Known for weight savings and durability, Seibon rear diffusers are molded to fit factory rear bumpers and underbody areas. Every component is constructed from high-quality carbon fiber with a consistent weave pattern. Seibon manufacturing processes allow for an exceptional carbon/resin ratio that makes their products extra stiff and also strong. For a stunning finish, their products are coated with a clear glossy layer of resin that does not chip or flake.
Get the great finishing touch in your modification project by installing a Seibon Carbon Fiber Rear Diffuser!
Seibon® - OE-Style Gloss Carbon Fiber Rear Diffuser
Features:
  • Finished in glossy clear coat that will not chip or flake
  • Aerodynamically designed
  • One-piece carbon sheet construction for the consistent weave pattern
  • Exceptional carbon/resin ratios for high stiffness and extra product strength
  • Manufactured from the highest grade carbon fiber raw material
  • Up to 50% lighter than the original panel
  • 6-month limited clear coat warranty
1 - 1 of 1 Posts
