1 - 17 of 17 Posts
I'm trying to compile a list of places that sell fully built (internals and all) engines.
There are already posts on the parts themselves buying different blocks themselves but I mean placing an order and having a built crated engine showing up at your door.
Many people may not like to go this route but (as I am now finding out personally) life happens and sometimes you're just not in the situation to collect parts and build your car that way. Hope this helps people out.
note: I don't think I'm breaking any rules since I'm not linking to anyone... right?
So here we go with what I've found so far:
To be clear this is not for internals or kits this is for the motor crated to your house ready to plop in the car.
AMS 2.2L
$19499.95
Includes
  • Sleeved AMS block
  • Precision AMS spec machine work on block & crank
  • AMS Spec JE Pistons w/ skirt coating
  • Manley "Turbo Tuff" I-Beam rods
  • High performance rod & main bearings
  • ARP main studs
  • Oil pump
  • Oil pan
  • AMS machined big-bore head gasket
  • AMS CNC ported cylinder head
  • +1mm oversized Ferrea valves and valvetrain components
  • ARP head studs
  • Kelford camshafts
  • Timing Chain components and covers
  • Aluminum Valve cover
  • All necessary gaskets
Specifications
  • Displacement: 2.2 liters
  • Stroke: 86mm
  • Compression Ratio:
  • 9.5:1 Street (best suited for pump gas)
  • 10.5:1 Race (best suited for race gas, careful tuning required for pump gas)
AMS Stage 1 2.0L $15999.95
Includes
  • AMS Spec. JE Pistons w/ skirt coating
  • Oil pump
  • Oil pan
  • ARP head studs
  • Kelford camshafts
Specifications
  • Displacement: 2.0 liters
  • Stroke: 86mm
  • Compression Ratio: 9.0:1
AMS Stage 1 Short block 2.0L $2899.95
Includes
  • Stock Bore Size JE/SRP Pistons
  • Manley I-Beam rods
  • Precise, documented hand assembly
Available Options
  • Sleeved AMS block including ARP main studs
  • AMS assembled EVO X gasket set
  • ARP head stud kit
  • New Mitsubishi oil pump
  • ARP main studs with align hone (not necessary with sleeving option)
  • Upgrade to JE pistons with skirt coating
Specifications
  • Stroke: 86mm
  • Compression Ratio: 9:1
**GOOD CORE REQUIRED
AMS Stage 1 2.0L $18799.95
Includes
  • Sleeved AMS block
  • ARP main studs
  • Oil pump
  • Oil pan
  • ARP head studs
  • Kelford camshafts
Specifications
  • Stroke: 86mm
AMS Stage 2 Short block 2.0L $5299.95
Includes
  • Sleeved AMS block
  • JE Pistons w/ Skirt Coating
  • ARP main studs
Available Options
  • ARP head stud kit
  • New Head Gasket
Specifications
  • Stroke: 86mm
More to come:
Buschur Racing Evo X Stage 3 2.0 Darton Sleeved Shortblock $4700.00(w/out core) $3050.00 (w/core)
Buschur Racing ultra high strength custom pistons
custom Manley rods
factory crankshaft is balanced along with the rest of the rotating assembly to ensure smooth high RPM operation.
Darton ductile iron sleeves
Cores are required
Buschur Racing Evo X Stage 3 2.0 $4400.00 (w/out core) $3050.00 (w/core)
custom Manley rods
SpeedCircuit Forged 4B11T Engine $6,099.00- $2,699.00 (depending on internals chosen)
Forged 2.0L Engine:
Specs:
* 86mm Arias, CP, Wiseco, or JE piston set. No clearance issues with oil jets.
* Pauter Billet chrome-moly forged 4340 rods, K1 rods, and Manley rods available.
* Overbored .0010" with the use of a torque plate to ensure roundness of cylinders with the installation of head studs.
* All OEM bearings and components.
* Fully balanced.
Optional:
* ARP main studs - requires an align hone and bearings
$8,098.00- $4,698.00(depending on internals chosen)
Forged 2.2L Engine:
Specs:
* 90mm Arias SpeedCircuit piston set. Forged 2618 Aluminum with heavy duty floating wrist pins. Wire style wrist pin locks. 4mm over stock bore. 9.0:1 compression ratio. No clearance issues with oil jets.
* ERL ductile iron sleeves, overbored to 90mm with the use of a torque plate to ensure roundness of cylinders with the installation of head studs.
* Modified OEM head gasket for overbore application.
* Fully machined and balanced.
Optional:
Note: 2.2L engines require Arias pistons.
MAPerformance Stage 2 Shortblock for Evolution X
2.0L $3599.99-$6066.98
(w/core depending on options)
2.0L $6199.99-$7466.98
(w/o core depending on options)
2.1L/2.2L $3699.99-$6166.98 (w/core depending on options)
2.1L/2.2L $6299.99-$7566.98 (w/o core depending on options)
(prices are an estimate given the vast number of options available)
Factory crankshaft and connecting rod configuration
Darton MID sleeves
Pistons available in 86mm (2.0l), 88mm (2.1l) and 90mm (2.2l)Included Services
  • Engine blocks visit our hot tank before and after machining for a clean, finished appearance.
  • Crankshafts are never cut / turned and receive a micro-polish treatment and balancing specifically for high performance applications.
  • Darton MID sleeves are installed allowing for the ultimate in strength even with a 90mm bore!
  • We utilize a three step honing process utilizing a 4B11T specific torque plate to ensure roundness. Our honing process is finished with a plateau hone for the absolute best cylinder wall finish and ultimate ring seating.
  • The last step in the machining process is resurfacing. We pride ourselves on the surface finish (RA) we achieve as it is of the utmost importance in regards to head gasket sealing.
Included Components
  • ACL Race Series Main and Rod Bearings
  • Darton MID Sleeves
  • Forged Connecting Rods
  • Forged Pistons
  • Crankshaft: We use standard size OEM crankshafts most frequently as we have not had a crankshaft failure to date. However, we realize that cores are hard to come by and there are weight advantages with some aftermarket crankshafts so we will happily build your shortblock accordingly!
Core or no core options available
Discussion Starter #5
yeah but those are kits not the whole block or short block built and shipped to the buyer.
Ah short and long block thread; http://www.erlperformance.com/mitsubishi-4b11
Code:
PACKAGE	DESCRIPTION	BLOCK TYPE	BORE	STROKE	LITERS	CR	PISTONS	RODS	CRANK	PRICE
BB1	Turbo Street/Strip	Sleeved	88	86	2.1	9.0:1	Wiseco	K1	Mitsu	$3,350.00
BB2	Turbo Race	Sleeved	87	86	2.0	9.5:1	CP	Manley	Mitsu	$3,700.00
BB3	Street Stroker	Sleeved	90	97	2.5	9.5:1	Wiseco	K1	ERL	$3,700.00
BB4	Race Stroker	Sleeved	88	97	2.4	9.5:1	Wiseco	Manley	ERL	$4,100.00
BB1N	Turbo Street	Stock Sleeve	86.5	86	2.0	9.0:1	Wiseco	K1	Mitsu	$2,350.00
BB2N	Turbo Street	Stock Sleeve	86.5	86	2.0	9.0:1	CP	Manley	Mitsu	$2,700.00
BB3N	Street Stroker	Stock Sleeve	86.5	97	2.3	9.5:1	Wiseco	K1	ERL	$3,250.00
Code:
SHORT BLOCK FEATURES
Fully Blueprinted Short Block
Forged 2618 Pistons from CP or Wiseco
Billet K1 H Beam Rods, or Forged Manley I Beam Rods
ACL Race Bearings
Mitsubishi Crankshaft or ERL Stroker Crankshaft
CNC Machined Ductile Iron Sleeves and Aluminum 6061 Deck Support
ARP Main Studs
Code:
AVAILABLE OPTIONS
ARP 1/2 Head Studs
$350
Custom Compression Ratios
$150
4B11 Block Core
$2000
4B11 Crankshaft Core
$600
Discussion Starter #7
:yeahthat:
http://www.maperformance.com/maperformance-stage-2-shortblock-for-evolution-x-map-evox-22-s2.html
http://www.maperformance.com/maperformance-2.0l-shortblock-for-evolution-x-stage-1-map-evox-20-s1.html
http://www.maperformance.com/maperformance-2.0l-shortblock-for-evolution-x-stage-1-no-core-required-map-evox-20-s1-nc.html
http://www.speedcircuit.net/product_info.php/cPath/65_87/products_id/403?osCsid=72133f3bb9ede3a744bdfb7ab936e406
Code:
[SC_FGD_4B11T]	$2,699.00
Click to enlarge
Looking to build an epic Evo X? Here's where to start:
Forged 2.0L Engine:
Specs:
* Fully balanced.
Optional:
Forged 2.2L Engine:
Specs:
Optional:
All aftermarket components are made to exacting tolerances with pride in the USA.
Note: Refundable core charge will not be refunded until your replacement core is sent to us.
Prices do not include freight and/or shipping charges when applicable.
Discussion Starter #9
Yeah I'm doing the Map ones but they have so many options its gonna take a while.
Since the first page is the most critical if you need more room just PM me a copy and paste of what you want up and I'll overlay my posts.
Discussion Starter #11
ok
Discussion Starter #12
I condensed what I had and sent it to you then I'll clean it all up and post your format.
hey hollywood, can somone with vast knowledge of stroker kits (i.e you) start a thread with the different kits (ERL, 2.1, 2.3, Speed circuit, MAP, AMS) and a quick summary of ideally what each one is good for. Maybe too, a quick description of the parts...the purpose would be for someone like me who does not have half the knowledge that you, hotdog, murlo26, have when it comes to all things mechanical.
I read some people say, i would go 2.2, slap a 35r and rev the shit out of it...or i would go with a 2.3 and a red....this is good for the strip, the road course, the street...blah blah blah
What do you think, give us something to do for the next half of day?
I am sure a lot more research has to go into this, but ERL's price on 2.3L Street blocks are good. 3250 for a 2.3L with a core exchange isn't too shabby.
FYI most of the kits on the market as of now are just increased cylinder bores and not "stroker kits." They become a stroker when the stroke is changed through the use of a bigger crank shaft and smaller pistons. From what I can gather, the bigger bored kits won't yield the high torque gains, but won't suffer the RPM caps like a stroker.... unless you rock a 2.5L
Any increase in displacement will yield more torque, no matter what assuming you keep the setup the same.
Overbore motors are win as they don't lose rpm ability. The stroker is needed though if you really want to get mad torque as you can safely only really overbore to 2.2L where the stroker can get up to 2.5L which is another 10-11 percent more yet.
Displacement is win no matter how you do it though.
1 - 17 of 17 Posts
