1 - 1 of 1 Posts
Performance Race Solutions Offers Built Short Blocks, Heads and turn key install services. We offer built short block packages to fit your needs, we highly recommend sleeving the Evo X blocks if you want to make excessive 450hp.
We offer any Piston and rod combination Pm us for details
PRS Stage 1 2.0l Short Block Includes:
Wiseco or Manley Pistons
Manley H-Beam Rods
ACL Race Series Rod & Main Bearings
All freshly bored and honed to each specific piston with a torque plate
Freshly Resurfaced
Balanced Assembly Including Crankshaft
Build Sheet
**GOOD CORE REQUIRED: Block must be complete with crank, 5 main caps, oil squirters, crank ring, and all components, cylinder walls must be undamaged
$2500 A good core is required, if you do not have a good core one can be provided.
PRS Stage 2 2.0-2.2L Sleeved Short Block Includes:
Wiseco HD Coated Pistons (86mm-90mm bore)
Darton MID sleeves
Manley Turbo Tuff I-Beam Rods
APR Main Studs
Freshly Resurfaced
$4300 + CORE
1 - 1 of 1 Posts
