or worse.. pull a Cooper S and use run flats >_< ughIs there a spare? They might try to get away with a 12 V compressor and a can of sealant.
The turbo impeller doesn’t look good once again for rallies as the earlier Evo 9 kept breaking the moment it was fixed with the 32mm restrictor and ended up using the Evo 8 turbo which was very strong. Hope the Evo X turbo would hold the 32mm restrictor….![]()
from other forum. hmm panasonic battery, why not energizer or optima lol.
What doesn't look good about it exactly?The turbo impeller doesn’t look good once again for rallies as the earlier Evo 9 kept breaking the moment it was fixed with the 32mm restrictor and ended up using the Evo 8 turbo which was very strong. Hope the Evo X turbo would hold the 32mm restrictor….
The pic doesn't load for me, but I'm assuming it's one of those thin batteries?I'll be replacing mine later down the road with one of these....
Its about 20-25lbs lighter.
That is significant weight savings. What's the price?I'll be replacing mine later down the road with one of these....
thats pretty awesome, take the spare tire and the ranch out, thats like 100 lb? then a new light weight exhaust to finish it off!I'll be replacing mine later down the road with one of these....
I just vomited a little bitrun flat tires.
Best weight reduction mod evar!and it involves me getting on my tread mill...
