That pill is designed to limit the amount of boost that is sent to the wastegate actuator. Removing the pill will have a negative effect and cause a boost reduction. You are supposed to remove it when installing a MBC because the way the boost is sent to the wastegate is different than with the stock boost control solenoid setup. However, as I mentioned before unless you are changing out the boost control solenoid to a fast reaction electronic type, or installing a MBC, this removal of the pill on it's own will cause you to lose power. Not trying to be a jerk, but you don't seem to understand how a stock turbo config with the bleed pill works, and perhaps this will help you to understand things a little more clearly.
