1 - 4 of 4 Posts
I just ordered up power slot rotors and Raybestos ST43 pads front and rear. Does anyone know if the rear st43 pads require an adapter to work with the oem factory calipers?
For my track set up, right now I'm running the AMS ss lines, Motul 600, oem rotors with Hawp HP+ front and stock pads in the rear. The Power slot w/ st43's should be a nice upgrade when the rotors finally give out. :D
· Premium Member
no need for adapters, they fit like a glove.
PS: your eyeballs may pop out due to the extreme braking potential of the ST43 pads. You have been warned.
No need for adapters but i would run the Girodisk titanium shims to prevent heat from boiling your fluid.
1 - 4 of 4 Posts
