Good call on this, it's definitely a possibility!Do you have a CAT still?
Clogged perhaps.
get the car in the air, remove the two bolts from front of the CAT to the DP, have a look inside and see if you can move the element with your fingers. It could be the o2 sensor too, check the cable is in good condition..Good call on this, it's definitely a possibility!
I believe you nailed it, will confirm tomorrow.Do you have a CAT still?
Clogged perhaps.
I will be checking the HFC tp tomorrow and lets see if that really is the case.if it was a cat it would make sense that the 02 sensor code popped up. hit it with a rubber hammer and see if lovely noises are heard. other than that, when one of the lines for my BOV was messed up, i would only pull at around that same rpm your saying. could very well be the bov or the line for signal to it, but i dont know anything about cobb bov's so...
That right there I think really is the problem, will check that tomorrow.Ive had this code P0134, my CAT element inside was spining around. The lamda sensor was then sending signals to the ECU to cut the boost. Car was slow as shit! Fitted a TP instead.
Oh yes I have, I did take off all the lines from EBC and BOV to test the lines, all are working just fine. Maybe the EBC and BOV are internally screwed...Double check your Grimmspeed 3 port vacuum lines. There could be a kink in one of the lines which will effect boost. In particular, check the line that normally routes back to the intake tube (vacuum).
the line that routes back to the intake is pointless, you can vent that to atmosphere if you want.Double check your Grimmspeed 3 port vacuum lines. There could be a kink in one of the lines which will effect boost. In particular, check the line that normally routes back to the intake tube (vacuum).
Which would be venting metered air to atmosphere. Not going to get into the VTA debate, just making sure this is understood. The MAF has already metered this air.the line that routes back to the intake is pointless, you can vent that to atmosphere if you want.
yea I know that. I meant VTA on that 3port line would have no effect on how his turbo was spooling.Which would be venting metered air to atmosphere. Not going to get into the VTA debate, just making sure this is understood. The MAF has already metered this air.
Indeed, it would have no effect. However if that line was plugged/crimped somehow, then when the 3 port opened to vent air back through the intake to release pressure away from the wastegate, it wouldn't be able to because of the plug, and consequently the pressure would not be released and would instead push open the wastegate, which would obviously result in him not being able to generate any boost (the issue he is having). Which is likely why someone previously suggested checking this line.yea I know that. I meant VTA on that 3port line would have no effect on how his turbo was spooling.
Thanks a lot HappyMint, I am off to run some work related errands then hitting the dealership to test out the HFC cat (gonna take it off and check inside and hit the sensor connector with a rubber hammer as suggested). If that doesnt change jack, I will order me a new MFI relay and if that doesnt fix it either... I will just drive down to cobb @ plano (5 hours away) and get it all fixed.http://www.evoxforums.com/forums/showthread.php?p=1034032#post1034032
In this thread they just resolved an issue that may be related. The MFI relay could be broken thus causing your solenoid to remain in the open position. This would mean no boost pressure would be diverted away from the wastegate and consequently would mean the ecu has no waste gate control.
5 hours??Thanks a lot HappyMint, I am off to run some work related errands then hitting the dealership to test out the HFC cat (gonna take it off and check inside and hit the sensor connector with a rubber hammer as suggested). If that doesnt change jack, I will order me a new MFI relay and if that doesnt fix it either... I will just drive down to cobb @ plano (5 hours away) and get it all fixed.
LOL, yes you can haha. 5 hours for only passing 1 state here. Anyhow...5 hours??I could drive through 5 countries in that time lol
good luck with your car:thumbup:
This is a very odd scenario, you would think the spring on the wastegate would allow the turbo to spool at least some until the boost pressure exceeds the pressure of the wastegate spring and opens the wastegate. Even if your 3 port was stuck open (diverting no air away from the wastegate) you should be hitting at least the PSI of whatever wastegate spring your car has. If I had to guess it'd be that your wastegate is cracked open somehow and is diverting exhaust and it is only until you hit a certain RPM that your turbo is flowing enough air that the cracked open WGA isn't diverting enough air to prevent spool.I did log the boost, let me upload it in a bit. Gotta get my AP out of the car and upload the data.
Its around 2psi till 4-4.5k rpm around 5k rpm it hits 16-17psi and stays there till 7-8k rpm. I am suppose to get 22-26psi and it is all I have been getting so far.
