1 - 20 of 94 Posts
Lets talk about racing seats…
Looking to replace both driver side and passenger side seats with wither Sparco or Recaro racing seats.
Reason for doing so:
1. Safety
2. Weight Reduction
3. Will keep my fat ass planted in the seat for once
The problem I am having though is that I know nothing about aftermarket seats, what to look for, what to get.
I was thinking about the:
Sparco Circuit II Drivers Seat
http://www.sparcousa.com/product/circuit-ii
Sparco Corsa Seat for Passenger
http://www.sparcousa.com/product/corsa
I am:
5’7
Medium Build
About 190 Pounds give or take
36 inch Waist
I will be running in NASA this season with intentions to start in TT
So my question is, is what I have listed a good start? The Stock Recaro’s have been ok for the past 2 seasons but I am looking to get something that will keep me in my seat a bit more.
Currently I run a Scrothe 4 point harness and install an autopower roll bar in the next couple of weeks.
I also don’t know what seat rails I should be looking for.
So Seats and Seat rails.. What are the best options out there? What is everyone else running?
Buy a cobra seat, theyre nicer and safer. Look around on track forums, and youll find cobra seats and schroth belts to be the best, and the best deal... I tried sparco and other crap, and i wouldnt bother again.., dont get adjustable, and make sure you use a sub strap.
I have cobra imola gt and schrotch clubman 3s for my track car. Also have the autopwer as well, so youre on the right path, to saftey.. Its really quite subjective, youll get lots of useless opinions, so be careful.
[Team IEG VP]
[STRIKE]1. Safety[/STRIKE]
[STRIKE]2.[/STRIKE]1. Weight Reduction
[STRIKE]3.[/STRIKE]2. Will keep my fat ass planted in the seat for once
That's my only comment. Stock seats will be as safe as any aftermarket seat, so having safety listed as your number one reason for wanting to change seats makes no sense.
Unless you plan on going full roll cage
I've thought of changing my seats as well, but the weight savings don't seem to be enough for me to warrant the change. If I had a Vette, that has bullshit seats from the get-go, yes. But we have fucking Recaros, and good ones at that, stock.
Qwertymess, I know that you have no issues wedging that fat-ass of yours in our current stockers, why mess with success? Knucklehead... :neener:
Discussion Starter #5
If im not mistaken the stock seats are made to work with the rest of the safety equipment stock in the car. Aren't the stock seats supposed to bend/sway <-cant find the right word for it... out of the way in the event of a roll over?
Isn't that the purpose of an aftermarket fixed back seat? To keep you in place strapped into a harness and allow the roll bar to do its job?
[E-Tuner]
Yes, but once you feel the difference between the stock seats and aftermarket ones, you will hate the stockers
Damn you Chet and your educated, informative experience! I'm trying to talk myself out of doing what Qwertymess is proposing to do!
Discussion Starter #10
Its going to happen regardless. I already have tried to talk myself out of it.
Seats are coming out tonight to fit the AutoPower roll bar in there.
Stock AMP is coming out
Stock Speakers are coming out
And since the seats are already out, might as well replace with something a bit better for what im using the car for. It only sees the track, so why not.
I can use a good office chair. Thats the plan for the stockers.
Discussion Starter #11
Safety = Fixed Back seat
Weight = A by-product of moving to racing seats
Also can run a 5-point without modifying stock seat, and will hold me in place better.
[X Performance Mod], [Racing Mod], [Local Team Mem
I have the Cobra SUZUKA Pro GT in my car (GT just means "for people with bigger asses"). They are excellent, but I wouldn't know anything about being better than the competition. The one thing that swayed me towards the Cobra seats is that they are all certified for use with a HANS device. Sparco seats are not always. Even the same seat in a different size will have a different HANS compatibility in Sparco, which is retarded IMO. The seat I wanted in Sparco was not HANS certified, so the choice was simple.
I purchased the seats from Harrison Motorsports (Mini and BMW Specialists) in Atlanta. They dropshipped them from Cobra.
BTW, the Buddy Club rails I used were absolute pieces of shit. They flex so much at the track that you can hear creaking sounds. grrrrr. I just purchased the Status racing brackets and handed everything over to Dino for the install once my motor is built.
Hope that helps. Here are some photos:
[E-Tuner]
How much do you weigh? I have the buddy club rails and they are solid
I'm 215 and have a 36 waist and am 6' 0.5". For the OP and even you, the non-GT should be just fine.
Fitment might be okay with other brands of seats, dunno. But with the Suzuka's, they really sucked. The thickness of the mounts is also really low. Compare to the Aluminum FIA bases I got from cobra, these steel ones were about 1/3 of the thickness. What was worse is that I could actually see some flex if I leaned on the seat. It was too late by the time I noticed it though. I also had to cut the mounting tabs on the rails to make them fit on the Cobra Seats.
Another good reason to get a new seat is the ability to run a 6 point harness rather than the ralleye 4 point one. 4 point is not ideal (ralleye 4 is acceptable), but 6 point is much better. Many people say that you need a cage and hans device if you are running a harness, though. It's a slippery slope...
I agree.
BTW ortho.....:holla:
1. Safety
2. Weight Reduction
I am:
5’7
Medium Build
36 inch Waist
Racetech.
[Team IEG VP]
The stock seats have airbags in them...
Fixed back seats are good. And that's why I said "unless you are going with a roll cage".
But safety wise the stock seats are going to be as safe or safer then any other seat unless you install a roll cage. And i mean a proper roll cage.
Now in terms of comfort and weight, that's fine. You can get some great weight savings out of replacing the seats. And if you want to go full race build, then that is a definite must. I agree
But for a DD/weekend warrior, you might get frustrated with a fixed back seat. Especially if you are a little heavier set as the seats you are talking about are literal buckets you have to squeeze into and out of. They're awesome, but not convenient.
I'm 6' 5"...does that make any difference? I have a 33 inch waste, but would my height necessitate the need for the GT?
1 - 20 of 94 Posts
