Radiator and hose kits available to keep your Evo cool on or off the track. Tons of mix and match combos available for any budget. Select a radiator, a hose kit, and fans if you need and then PM us for the special EvoX Forums price.
AUTHORIZED DEALER FOR OVER 300 PRODUCT LINES
Like us on Facebook for Facebook only specials!
Agency Power
The all aluminum radiator features a high pressure radiator cap, aluminum construction, and mounting tabs for a direct OEM replacement. The factory fans and radiator hoses will fit with no modification. This kit is very easy to install and should only take about 1 hour. In addition to having a larger cooling capacity, the aluminum radiators are much more durable then stock. The factory plastic end tanks can crack under extreme heat and pressure. Under racing conditions, your water temperatures can near boiling points. As tested under the intense Arizona heat conditions, the aluminum end tanks and larger core size help keep the temperature down by at least 15F degrees
Agency Power Aluminum Radiator Kit
Koyo
Designed for applications where engine configuration/size cause clearances issues for thicker core radiators. In this case, the 36mm V-Core Series will suit your needs. Intended for both circuit and daily use.
All Koyorad V-Series All Aluminum Radiators are Nocolok brazed, designed as a factory fit, direct bolt in with no engine modifications necessary, and retain mounts for the stock fan shrouds and fans.
Koyo Radiator - V-Series
BlackWorks Racing
BlackWorks Racing is a great upgrade for your street car, weekend warrior, or full on track car. With our dual core design, cooling your vehicle is not a problem. The BlackWorks Racing radiators will keep your engine cool even under the most extreme high heat racing conditions, or driving in the high heat hellish temperatures in the desert of Arizona.
BWR Aluminum Radiator
Mishimoto
Whether you are a daily driver looking for an upgrade to your OEM radiator, or a racer looking for a dependable quality radiator, we have just what you are looking for! Mishimoto Performance Radiators are 100% brazed aluminum, ensuring a lasting lifetime of efficient cooling.
Mishimoto Performance Radiator X-Line
Mishimoto has just released the new X-Line of high performance aluminum radiators. Each new X-Line radiator application has 3 rows for a core that is 25% larger than standard radiator applications. The triple core design of the X-Line radiator allows more coolant to flow through, maximizing engine cooling capacity. Each application is designed as a direct OEM replacement, with no customization required for installation.
Agency Power Hoses
The amount of heat a performance motor puts out is far greater then most standard designed engines. For high performance needs, keeping a cars engine temperatures down and efficient is EXTREMELY important. Agency Power now offers this 5 ply silicone radiator hose kit for your Vehicle. These hoses replace your factory hoses. The OEM rubber hose tends to burst under extreme heat and crack over time. These silicone hoses improve flow and are not affected by heat like rubber hoses. They come in 3 powerful colors. Glossy black, red, or blue are available. Each hose kit includes new clamps for easy installation.
Blue and Red Available.
Mishimoto Radiator Hose Kit
Mishimoto Radiator Hose Kits are made with a dual layer combining high grade silicone and Dupont Nomex technology to provide efficient heat reduction and increased pressure tolerance.
Specifications
Interior Color: Orange
Interior Material: Nomex
Exterior Color: Black/Blue/Orange/Red
Exterior Material: Silicone
Max Temperature: 330 F
Blue, Red, and Black Available.
Mishimoto Radiator Upper Hose Aluminum Kit
Because factory radiator hoses are made of rubber, they are prone to various damage such as swelling or cracks. The Mishimoto Aluminum Upper Radiator Hoses are CNC mandrel bent and made of high-quality T6 temper aluminum. With three colors to choose from, Mishimoto Aluminum Upper Radiator Hoses offer a colorful, strong, and stylish replacement to your factory rubber radiator hoses. Our aluminum upper radiator hose kits include silicone couplers and t-bolt clamps, with every component backed by an excellent lifetime warranty.
Samco Hose Kit
The Samco Sport Radiator Hose Kits provide a unique opportunity to upgrade your intercooler hoses to a product that is simply un-rivalled worldwide for performance and looks. These direct replacement silicone hoses are available in 7 striking colors to blend with your engine the way YOU want. Whatever color you choose just remember, you’re fitting the finest radiator hoses that are designed to perform under pressure.
Red and Black in stock. Can Special order White, Pink, Yellow, Green, Urban Camo, and more
Mishimoto Slim Fans
The Mishimoto Radiator Fan can be used as an upgrade to the OEM fan for more efficient cooling or fitment issues with aftermarket products. With the Mishimoto Radiator Fan’s slim design, the fan can easily be installed flush against a radiator.
For universal installation, use Mishimoto universal fan mount kit. (P/N: MMFAN-Mount)
Available in 10”, 12” and 14” Applications.
Pick a size and qty.
Agency Power
Koyo
BlackWorks Racing
Mishimoto
Agency Power Hoses
Specifications
Samco Hose Kit
Mishimoto Slim Fans
