I took the car to Mitsu a few days ago and they changed the rear diff gear lube, but I guess I wasn't clear enough and they didn't change the ATF fluid. Today I went back and watched their "evo tech" who went to special training for mitsu on how to work on Evos bleed the ATF fluid from the system. He even had another tech sit in the driver seat while on the lift and turn the steering wheel left in right while bleeding it. I went up and asked him about it and I was told that he was trained at mitsu school to bleed the ATF fluid from the rear diff when it was changed.
I was under the impression that this was simply a drain and fill just like the gear lube in the rear diff? I mean even the service manual doesn't seem to indicate that the ATF fluid needs to be bled. I also saw him in the trunk area with the side latch working with the fluid reservoir? Did he do more than the typical change? I asked him to show me where he was draining from and he showed me the bolt and it's pretty clearly marked as the torque transfer/ATF fluid.
I'm so confused!
I'm so confused!
