1 - 10 of 10 Posts
Is it common for the reverse/back up light to come ON for few seconds then go OFF? Just noticed this after changing them out for LEDs, will change them out for incandescent bulbs and give an update.....
I just thought it was really ODD...
Buy this and call it a day. (Must bestbinstalled un parallel with the plus and minus cable. Clips are provided usually with those. Not cutting needed.
I had the same problem. Just in safe.
US $6.29 | 4PCS/set 25W 6ohm Load Resistor 12V Resistance for Car LED Flash Indicator Controller CANBUS Problem FREE SHIPPING Adebayor
LEDs didnt throw enough Lumens.... So i did the mentioned adaptors and bulbs... Still not enough lumens for my old eyes at night but better then factory incandescent bulbs
Might have to take off the Tint on front windows..
Discussion Starter · #7 ·
So the Gy6.35 HIR bulbs go out after 3 sec like the LEDs did.
LEDs not enough resistance
HIR too much resistance
Lower wattage HIR?
Discussion Starter · #8 ·
Doing a custom harness to fix this problem
I was told by Diode Dynamics that their LED product offering for reverse lights are literally plug and play.
  • Like
Reactions: BenMara
You need to calibrate the LEDs after you install them. I bought some LED lights from https://www.vont.com/product/vont-car-smart-strip-light/, and I immediately went to a car repair shop so they could install them on my car and, most importantly, properly calibrate the new lights. The calibration of the LED lights is very important because it depends on your and the other drivers' comfort on the road. If you don't calibrate the LED lights, the light level will be too high, so it can blind other drivers and create dangerous situations on the road.
1 - 10 of 10 Posts
