check your fpr hose and relays
i checked the hose, (the little skinny guy kinda under the dip stick) and the AC was not on, i got a cat back exhaust, K&N intake, synapse Bov, and im the 2nd owner of the car, i think the prevous owner might have had it tunedcheck your fpr hose and relays
did your car ever stall tho? and it only happens sometimes, its very random. i think if it was caused by the catback it would happen every time i came to a stop, not just sometimes. i could be wrong tho.Is your car tuned for those mods?!? if it had a test pipe, or some exhaust and not tuned for it, it may idle like that. When i put my test pipe on it idled like that before i got a tune
Yes it would stall, and it stalled for 4 years up until my last thread.. Check your relays...did your car ever stall tho? and it only happens sometimes, its very random. i think if it was caused by the catback it would happen every time i came to a stop, not just sometimes. i could be wrong tho.
visually everything looks okay. are you implying that i should replace it? or what else should i do to trouble shoot?Hows your relay?? Did u check them?
i clicked on the link that joshesevo22 posted below, found the relay,(which is black) removed it and shook it. it does almost make a little squeaky rattling sound...so its shot?Do the "salt shaker test" remove the relay and shake it close to you ear then if something moving inside u need to replace them..
What color of your relays?
^ yesi clicked on the link that joshesevo22 posted below, found the relay,(which is black) removed it and shook it. it does almost make a little squeaky rattling sound...so its shot?
yep, fpr line is goodCheck the fpr line. It may have come out. It's on left under fuel rail
