1 - 13 of 13 Posts
2008 GSR
I have been having an issue with my rpm while driving and I can't figure out what the problem is. About a week ago I took my car to the local dealership and they did and turbo D service and an ecu reflash which fixed one problem but seemed to create another. When I'm driving along (on the highway it is more noticeable) and slowly accelerate the rpm bounce just a little bit and the car feels like its sort of jerking a bit. It is most noticeable when i'm doing 90km/hr (55mph) and slowly accelerate to 110km/hr (68mph) and I'm in 5th gear. I've noticed it while accelerating in 3rd and 4th as well and it only happens between 2500-3500rpm.
I took it to the same dealership today that did the ecu reflash last week and the took it for a test drive and said they couldn't replicate the problem but were unwilling to take it up to 100km/hr due to 'road conditions'. The roads aren't really that bad today so it seems like an excuse because they don't want to find the problem for some reason. They said that I could be running too many electronics, the only thing i have is an HID conversion kit and then they also said it seems like from what I'm saying it might be my spark plugs but I changed those out a month ago. Then they said that I might not be warming it up enough before I start driving, I let it warm up for at least 20 minutes before I move it. In the end they said that unless there is an error code they have no idea what it might be and to just keep driving it and if it gets worse to bring it back. I know something is wrong and I really want to figure out what the problem is. Does anyone have any ideas what this could be? I checked the Vacuum line for fuel pressure regulator and it is connected so thats not the problem. The only thing I've changed on the car since I got it was putting on a turbosmart BOV, is it possible this could be the problem? I uploaded the video to youtube and if you watch it near the end when I reach about 3200rpm it is most noticeable, it doesn't look like much but it is very noticable when I'm driving. http://www.youtube.com/watch?v=kVvMSlXaaSc&feature=youtu.be
You need a new clutch
Or you're getting BOV flutter, it's really hard to tell from that video..
Discussion Starter · #4 ·
I got the car in the end of November and they said that the clutch was going to be needed to be replaced but it wasn't too bad, maybe that is the problem.
How many km's on the car?
Do you ever launch it?
Are you new to driving stick?
Considering your car is a 2008, I'm guessing you got it 2nd hand... The first owner may have launched the car a bunch. Replacing clutches is common and the stock GSR clutch is nothing to write home about. I'd put my money on that being your issue.
it has 55000km
I've been driving stick for years
and I launched it once
55,000km sounds about right for a averagely driven OEM clutch. Some last longer, some fade quicker...
The video doesn't look like the classic rpm rise followed by drop that you see when the clutch slips. Seems more like something is not quite running right. Do you have any mods? Also, I'd get under the hood and check your FPR vacuum hose to make sure it didn't pop off.
Quick clutch test:
while crusing in 5th at highway speed, give it a good amount of gas and watch the rpms. If you see a rise followed by a drop and then a steady increase as you gain speed, the clutch is slipping just while you're building boost.
· Premium Member
Here's a couple of videos of mine when my clutch was on its way out. I had the accelerator pedal depressed by a constant amount all through each of the videos. This is what you should see. Best way to replicate and check would be to get to cruising speed at 3K RPM on 5th gear, and then mash the throttle. You should see the following if your clutch is slipping. Has nothing to do with any software.
Discussion Starter · #11 ·
I would bet my ass it's BOV Flutter :D (though I didn't watch the video).
You were right, I took the turbosmart bov off and it totally fixed the problem.
OH YEAH. OH OH OH YEAH. OH OH OH YEAH. DO THE HAPPY DANCE!!!!
:dancebanana::dancebanana::dancebanana::dancebanana:
Glad you got it figured out.
Hey,
I have a turbosmart BOV and haven't had any issues with it. What setting did you have yours at? Did your BOV have kinks in the vacuum tube? Mine has a longer vacuum tube than the stock one. Also, you need to make sure you clean and lube the BOV every year - how-to is on their website.
I generally don't use my BOV in the winter, as I'm afraid of getting salt and sand in my engine.
1 - 13 of 13 Posts
