1 - 15 of 15 Posts
Anyone with an SE remove the lip off the trunk and replace it with something better ?? If so how did you remove the factory trunk lip ??
Oh, ouch.
I have a feeling you'll be in for a surprise.
The factory lip spoiler includes instructions mentioning a hole being drilled into the edge of the deck lid. Instead of doing this, mine is held on with tape alone and I dremel'd that little tab off that's supposed to go into the trunk.
If the factory installs as the factory part instructions say, you're in for a lil surprise.
You'll have to make this hole weather tight when switching to something "better," and if you're looking to get a wing of any kind and remove this lip, you'll have that hole in the middle.
But aside from that, I believe one screw in the center holds that tab in, or no screw at all, and there's a lot of extremely tough double-sided tape. Similar to emblem tape. Heat (baking in the sun all day is best) + dental floss + goo-gone is a sure bet.
wow i didnt know you had to drill a hole just for the trunk lip? ill just double sided tape it
When I had my STi, I did the same thing. Went wingless and then decided to add the lip spoiler from the STi limited. The instructions also mentioned adding a hole for the spoiler. I also cut that tab off and the lip was held on with 3M double sided tape. The wing never budged, even at 130+ mph. Also, this is a good method, b/c you can remove the lip spoiler at any time and go back to completely wingless.
Discussion Starter #8
Im just hunting around looking at diffrent trunk lips and wanted to know how the factory one came off before I bought anything. looks like its staying. Dont want to deal with havin to fill holes and what not.
bringing back this thread
i am looking for the mr/se trunk lip i can not find part number for it do they still sell oem ones?
[X General Mod], [Sales Mod]
Oem... not sure.
i had the rexpeed cf lip on my trunk. Folks thought i had an MR... until they saw big pieces of tape covering the wing holes
Oem... not sure.
how did the rexspeed one fit ?
1 - 15 of 15 Posts
