1 - 10 of 10 Posts
Neo, my car, is showing me the SERVICE ENGINE SOON light. With only 8700miles I get this light :tumbleweed:
Any ideas?
Thank you in advance
That's not a code issue.
It's a message from the Service Minder settings that the normal maintenance schedule has come up (time/miles). All the settings are detailed in the owners manual.
Discussion Starter · #4 ·
Thank you guys!!!
I wil take it SUBARU, because there is not Mitsubishi...
Opinions?
Oil change done, light still ON.... time to read the manual...
Unless someone tells me how to do this....
thank you in advance
There is nothing to detect when the engin oil is changed - you have to tell it.
The process to tell it is different for the different years. Easiest to do with the MMCS, if so equipped. If no MMCS, you will need to read the Owners Manual
Discussion Starter · #7 ·
Perfect, thank you.... I am on it...
Appreciate it
Discussion Starter · #8 ·
I changed the oil, tried what the manual said, I YouTubed it... and nothing
And all the sudden I started the car and it went away
Problem solved???
1 - 10 of 10 Posts
