Since my AYC pump broke for the third time and now there's now easy way of rebuilding it I'm ordering a new pump. This time I want to make sure that it lasts a long time like it should. After reading lots of threads on the issue, I came across many useful advices on how to preserve the pump.
So, may be it's good to have a thread that summarizes all the experience and hopefully will result in a overall solution that everyone should implement.
So, the firs step is protecting the pump against rust by coating it with an anticorrosion lubricant.
The second issue is cold weather and pump going bad due to the increased viscosity of the fluid. There, I was thinking, I could put up a simple heating solution that would connect the pump circuit only after the fluid or the pump itself is at a certain temperature (t1). The heating will be operating from a 12V power when the car is running and will be truned off when the temperature (t2) is , let's say 10-15 degrees higher than t1.
The question here is, what exactly should be heated: the pump itself, the liquid reservoir, some hoses?
Another solution would be to reprogram the ACD ECU so that the pump is turned on at a certain temperature of the liquid, or if there is no such a measurement, some other parameter - time, oil temp, transmission oil temp, etc. As far as I know from checking evom, ACD tuning is already possible, so making this simple mod should not be a problem.
Please share you experiences and ideas.
