Note the boot CD ISO provided only works with the two IDE channels Primary/Secondary Master/Slave configurations.
After the drive is connected to an IDE port, boot to the CD. Once it comes to the A:\> prompt, enter “unlockhd.bat” and press Enter. When the screen asks for which drive to unlock, select the proper option (Primary Master, Primary Slave, Secondary Master, Secondary Slave). Proceed until it returns back the A:\> prompt.
You can check the lock status of all attached drives using unlockx.bat.
Restart the computer. It should now show the drive letters assigned (chart below is in DOS format; Linux partition order is different!) to the six hard drive partitions. If you want to make a backup image, now is the time to do it. If you use the boot CD with no other drives connected, the partition order will be the following:
C: is the NAV files partition. 20481MB Primary 1
D: is the Screen partition. 1027MB Logical drive
E: is the CDDB database partition 1027MB Logical drive
F: is the AVUNIT (Music Server) 5436MB Logical drive
G: is the swap partition 125MB Primary 2
H: is the Loading partition 509MB Primary 3
Note that the drive letter/partition order will vary for other operating systems, such as Linux.
All partitions are TFAT. If you choose to play with the partitions, be careful to keep the same volume labels and Volume ID values. Note that the NAV partition Volume ID changes with the Navigation software version – updating to newer maps will change the Volume ID. Additionally note that most files and directories are Read-Only, 0555, except the Music Server files which are 0777.
Note the stock Music Server partition is ~5.4GB, which means it will hold just shy of 100 CDs. I imaged the entire [unlocked] drive to a larger capacity hard drive, Toshiba MK8050GAC at 80GB, and then expanded the Music Server partition to slightly larger than 50GB. Haven’t filled it up yet and I’ve got over 350 CDs recorded there so far.
The original drive, on the 2008 models. is either a Toshiba MK3029GAC (30GB) or a Toshiba MK4036GAC (40GB). I have tried using Seagate’s series of 80GB automotive hard drives with mixed results while the Toshiba MK8050GAC (80GB) has always worked flawlessly.
Once the drive is unlocked, use the USB adapter to mount it to a computer for file copying/editing. If you mount to a 32-bit Windows or newer, the file/directory names will display in LFN format (long file names).
