Performance
2.0l by Ivey
-ETS V2 Catback
-ETS Test Pipe
-AMS Wide Mouth Down Pipe
-MAPerformance 3.5" Intake
-AMS FMIC
-AMS UICP & LICP
-FP Black Turbo
-Blouch WGA
-GSC S2 Cams (274/274)
-Manley Turbo Tuff Rods
-Wiseco Pistons
-Clevite Main Bearings
-Supertech Valve Springs & Retainers
-HKS Head Gasket 1.0mm Thick
-HKS Spark Plugs
-P&P Head
-APR Head Studs & Main Studs
-GrimmSpeed 3 Port Boost Solenoid
-Synapse BOV Kit
-Tuned by Vinny Ten Racing
C16 Race Fuel
550awhp-458tq @ 29lbs of boost
Pump Gas
465awhp-366tq @ 29lbs of boost
Fuel System
-UR Fuel Pump Kit
-AeroMotive FPR (Not installed)
-AeroMotive 340lph Fuel Pump
-ID 1000cc Injectors
-AMS Fuel Rail (Not Instaled)
-Braided Lines and Fittings (Not Installed)
Engine Bay/Other
-MAPerformance Air/Oil Separator
-AMS light weight Battery
-RexPeed CF Hood Dampeners
-AMS Base Bushings
-AMS Under Hood Shifter Bushings
-AMS Radiator Hose Kit
-Mishimoto Radiator
-Mishimoto Aluminum Fan Shroud
-HKS Special Edition Oil Cap
Interior
-AMI Customs Fiberglass A-Pillar Dual Gauge Pod
-52mm AEM Digital Boost Gauge
-52mm AEM Digital UEGO
-TWM Short Shifter
-TWM Big Type-R Flat Black weighted shift knob
-T1R Shift Boot
-Compustar 2-Way Alarm
-CF Vinyl Trim
-CF Vinyl A-pillars
Exterior
-Window Tint 22% Front 8" Tint
-Tinted Side Markers
-DeBadge
-Aero Rear Lip
-3M Clear Bra
-RS Fog Delete Kit
-APR Vortex Generator(not installed)
Wheels/Suspension
-Matte Black Enkei RPF1 18x10.5+15 *Track Rims*
-RPF1 Centre Caps
-Proxes R888 275/35ZR18 *Track Tires*
-Stock Enkei's
-Project Kics R40 Neo Chro lug nuts
-Rolled rear Fenders
-SS Brake Lines
-HSD Coilovers
-Hotchkis 32mm Sway Bars
-Racingline Front/Rear Endlinks
-WhiteLine Front Center Adjustment Kit
-GiroDisc 2pc Slotted Floating front & Rear Rotors
-Girodisc Front and Rear Ti Heat Shields
-Raybestos ST43 Front & Rear Brakes *Track Only*
-AMS Brake Duct Kit
Transmissons
-Shep Built Transmission
-Shep Built T-Case
-Buschur Diff Pins
-Exedy Triple Plate HD Clutch
-Magnus CMC
Day I bought March 2010
Track Day (Stock Block FP Black)
Need more Powa dec. 22nd 2011
A Bit Dirty from the Underspray (Winter Driven)
Dyno
2.0l by Ivey
-ETS V2 Catback
-ETS Test Pipe
-AMS FMIC
-AMS UICP & LICP
-FP Black Turbo
-Blouch WGA
-Wiseco Pistons
-HKS Spark Plugs
-P&P Head
-Synapse BOV Kit
C16 Race Fuel
Pump Gas
Fuel System
-UR Fuel Pump Kit
Engine Bay/Other
-AMS Base Bushings
-Mishimoto Radiator
Interior
-TWM Short Shifter
-T1R Shift Boot
-CF Vinyl Trim
-CF Vinyl A-pillars
Exterior
-DeBadge
-Aero Rear Lip
-3M Clear Bra
-RS Fog Delete Kit
Wheels/Suspension
-RPF1 Centre Caps
-Stock Enkei's
-SS Brake Lines
-HSD Coilovers
-AMS Brake Duct Kit
Transmissons
-Shep Built T-Case
-Buschur Diff Pins
-Magnus CMC
Dyno
