1 - 3 of 3 Posts
hey all i just wanted to give a review so that my fellow X owners dont make my mistake in buying a sparco steering wheel hub adapter. the use the hub from the eclipse and while the splines are the same the hub does not clear the electronic harness ring. so unless you remove everything elecrical related on your steering column you can use this hub. that being said if you have an eclipse i have a sparco hub for sale. anyhow ther's the heads up all.
1 - 3 of 3 Posts
