See if you can get your hands on a scanner that will read live data from the airbag module.
It's not likely that both side's G Sensors would fail at random, plus starting with ALL the airbag codes at first points to an issue with the module. I'd check the module power and ground to start though just to make sure you have a good ground and voltage is correct.
