For non-SSS (Halogen Headlights) upgrading to SSS (OEM HID Projectors): The DRL Signal will still be passed through your Low Beam 9006 Plug. Simply put, this signal is at a lower voltage. Therefore, it will cause your HIDs to flicker and/or short out--which does cause damage.
You can disable the DRL's by the use of my DRL Bypass (Plug & Play). Unfortunately, the OEM HID Ballasts have OEM-specific plugs/sockets which are incompatible with my DRL Bypass. Therefore, the only way to utilize my DRL Bypass is to use an Aftermarket D2S HID Kit + D2S Adapters.
I personally had my lights retrofitted with TSX Projectors. They also share D2S Bulbs and I've been running this configuration for years now with no problem.
In Conclusion:
1. Yes, you can use my DRL Bypass with OEM HID Projectors to eliminate the Daytime Running Lights.
2. No, you cannot use the OEM HID Ballasts with my DRL Bypass.
3. To use my DRL Bypass you will need an Aftermarket D2S HID kit + D2S Adapters (most kits include these).
4. Yes, there are other ways to eliminate the DRL's with the use of creative wiring/splicing or messing with the fuse box. Personally, I prefer a Plug & Play solution.
PS. Thank you for all those who mentioned my harness!
