Well I just purchased a set of SSS headlights and after installing them I am having 2 issues. The car is a base model GSR.
1. The passenger side high beam is not working. I tried switching the bulbs to see if it was a bulb and it did the same thing. The same bulb worked fine on the driver side, on both low and high beams. I checked all my connections (only 2 plugs) like 20 times to make sure it was in correctly and it was. So does anyone have any idea of what else it could be?
2. The driver side project seems to be moving... not just the projector itself, but the whole housing. This includes the projector and the SSS model DRL bulb attachment. It seems like the swivels left and right a little. Is this for the headlight adjustment or is the headlight broken?
Any help or input will be greatly appreciated... Thanks.
