Getrag 6DCT470 TRANSMISSION
6-speed, transverse, dual clutch transmission
Max. Torque Capacity 470 Nm
Weight (dry) 99,5 kg
Installation length 348 mm
Input Shaft - Differential 197/207/215 mm
Gear Spread Ratio 4,99 – 6,48
Max. Gross Vehicle Mass/Gross Trailer Mass 2250 kg/3900 kg
Shifter System hydraulic shift actuation
Miscellaneous 2 x 2-shaft design parallel wet clutch system integrated electronic controls
This is the mitsubishi photo of a cut-away SST. It matches exactly with the Getrag 470.
Oh well I was hoping it would hold 400 torque. Maybe the clutches (which I believe are made by Aisin) are customized and have been beefed up.
