1 - 19 of 19 Posts
Here my SST Slip Analyzer software
https://drive.google.com/open?id=0B2hhlN7v68k8RlFYdkpOMC1jdDQ
and one sample log
Program parse Evoscan logs and analyse SST slip, clutch temperatures and gear change time. If there are slip - display only this short part of log. Main idea - plug notebook and race (AutoX, Cicruit). Then analyze several lines of log, not tons, or nothing when there are no slip :)
In Evoscan your should check
RPM, Speed, Load,
ClutchSlipSpeedOdd, ClutchSlipSpeedEven,
ClutchTempOdd,ClutchTempEven,
ClutchPressureOdd,ClutchPressureEven,
sst_gear
to log "sst_gear",your should add this code to evoscan xml.
Code:
        <DataListItem DataLog="N" Color="" Display="SST-Mode (1 - S-SPort; 2 - Sport; 3 - Normal)" LogReference="sst_mode" RequestID="CAN29-0" Eval="x" Unit="mode" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="3" ChartMin="0" ChartMax="3" ScalingFactor="1" Notes="CAN 29-0 (Selector position/directly correlates to display)
3 = Normal
2 = Sport
1 = S-Sport" Priority="1" Visible="False" LogHide="false" />
        <DataListItem DataLog="N" Color="" Display="Manual Mode Selector/slap shifter (1 - Manual; 0-Auto)" LogReference="shift_mode" RequestID="CAN30-0" Eval="x" Unit="mode" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes="CAN 30-0 (Manual Mode Selector/slap shifter)
1 = Manual
0 = Automatic" Priority="1" Visible="False" LogHide="false" />
        <DataListItem DataLog="N" Color="" Display="Gear Position Sensor" LogReference="sst_gear" RequestID="CAN31-0" Eval="x-48" Unit="Gear" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="100" Notes="CAN 31-0 (Gear Position Sensor)
80 = Park
82 = Reverse
78 = Neutral
129 = Automatic 1st
130 = Automatic 2nd
131 = Automatic 3rd
132 = Automatic 4th
133 = Automatic 5th
134 = Automatic 6th
49 = Manual Mode 1st
50 = Manual Mode 2nd
51 = Manual Mode 3rd
52 = Manual Mode 4th
53 = Manual Mode 5th
54 = Manual Mode 6th" Priority="1" Visible="False" LogHide="false" />
enjoy ;)
First of all I want One slip variable that describes slip between engine and wheels by choosing slip_odd or slip_even depending on gear. Then I can use Numbers\Excel and filters.
Discussion Starter #4
Something like this from 500kb log :)
239: 1 > 2, 0.99 sec, 1969 (L 27); TempDelta 0.00 (Temp2 53.25); LinesCount 4;
345: 2 > 1, 2.50 sec, 977 (L 20); TempDelta 0.00 (Temp1 53.00); LinesCount 10;
371: 1 > 2, 0.50 sec, 2750 (L 67); TempDelta 1.25 (Temp2 54.75); LinesCount 2;
385: 2 > 3, 0.50 sec, 6539 (L 248); TempDelta 10.25 (Temp1 63.25); LinesCount 2;
392: 3 > 4, 0.26 sec, 6219 (L 258); TempDelta 5.75 (Temp2 60.25); LinesCount 1;
402: 4 > 5, 1.49 sec, 4891 (L 16); TempDelta -0.75 (Temp1 59.75); LinesCount 6;
431: 5 > 4, 0.25 sec, 2977 (L 25); TempDelta 0.00 (Temp2 55.50); LinesCount 1;
462: 4 > 5, 1.24 sec, 3062 (L 11); TempDelta 0.00 (Temp1 55.50); LinesCount 5;
526: 5 > 4, 0.50 sec, 2688 (L 16); TempDelta 0.00 (Temp2 55.25); LinesCount 2;
539: 4 > 5, 0.48 sec, 4289 (L 242); TempDelta 2.25 (Temp1 81.00); LinesCount 2;
559: 5 > 4, 0.49 sec, 2898 (L 22); TempDelta 0.25 (Temp2 55.50); LinesCount 2;
668: 4 > 5, 1.50 sec, 3594 (L 11); TempDelta 0.00 (Temp1 58.25); LinesCount 6;
730: 5 > 4, 0.50 sec, 2844 (L 12); TempDelta 0.25 (Temp2 58.75); LinesCount 2;
737: 4 > 3, 0.49 sec, 2961 (L 12); TempDelta 0.00 (Temp1 59.25); LinesCount 2;
748: 3 > 2, 0.50 sec, 3031 (L 17); TempDelta 0.00 (Temp2 59.00); LinesCount 2;
758: 2 > 1, 0.49 sec, 2641 (L 11); TempDelta 0.00 (Temp1 59.25); LinesCount 2;
837: 1 > 2, 0.51 sec, 2641 (L 73); TempDelta 1.25 (Temp2 60.75); LinesCount 2;
843: 2 > 3, 0.50 sec, 2977 (L 125); TempDelta 1.00 (Temp1 66.75); LinesCount 2;
849: 3 > 4, 0.52 sec, 3109 (L 150); TempDelta 2.00 (Temp2 62.75); LinesCount 2;
856: 4 > 5, 0.50 sec, 3055 (L 152); TempDelta 1.50 (Temp1 66.50); LinesCount 2;
863: 5 > 6, 0.25 sec, 2719 (L 153); TempDelta 1.25 (Temp2 63.50); LinesCount 1;
877: 6 > 5, 0.51 sec, 2383 (L 17); TempDelta -0.25 (Temp1 64.75); LinesCount 2;
886: 5 > 4, 0.49 sec, 2922 (L 12); TempDelta 0.00 (Temp2 62.50); LinesCount 2;
903: 4 > 3, 0.51 sec, 3352 (L 36); TempDelta 0.00 (Temp1 62.50); LinesCount 2;
914: 3 > 2, 0.74 sec, 3938 (L 12); TempDelta 0.25 (Temp2 62.00); LinesCount 3;
946: 2 > 3, 0.49 sec, 4859 (L 170); TempDelta 3.75 (Temp1 65.50); LinesCount 2;
953: 3 > 4, 0.50 sec, 5078 (L 295); TempDelta 5.00 (Temp2 66.75); LinesCount 2;
959: 4 > 5, 0.49 sec, 4734 (L 259); TempDelta 5.75 (Temp1 70.00); LinesCount 2;
965: 5 > 6, 0.49 sec, 4148 (L 280); TempDelta 4.75 (Temp2 70.25); LinesCount 2;
1110: 6 > 5, 0.75 sec, 2844 (L 22); TempDelta 0.00 (Temp1 63.00); LinesCount 3;
1144: 5 > 4, 0.50 sec, 2578 (L 12); TempDelta 0.00 (Temp2 63.25); LinesCount 2;
1148: 4 > 3, 0.50 sec, 2844 (L 17); TempDelta 0.00 (Temp1 63.25); LinesCount 2;
1152: 3 > 2, 0.52 sec, 3227 (L 12); TempDelta 0.00 (Temp2 63.25); LinesCount 2;
1306: 2 > 1, 4.00 sec, 1367 (L 17); TempDelta 0.25 (Temp1 63.50); LinesCount 16;
Gear Change Time = target_clutch_end_slip-current_clutch_start_slip;
L - Load
TempDelta = ClutchTemp_After_Shift-ClutchTemp_Before_Shift.
Some GUI and it will be very powerful and easy to use to find something like
TempDelta 10.25
Second part it's some analyze between shifts.
I tried to download it:
Windows Defender found Malware: Trojan:Win32/Spursint.A :(
I have Windows 10
I don't know if it's false positive, I won't take the risk, may be you should analyse your PC ;)
Having source code shared on Github would be great :)! I would be happy to collaborate on that!
Discussion Starter #7
It was build and uploaded on W10 with WinDefender realtime protection and 14.02.2016 updates. Rebuilded, ReUploaded :)
It's all good now, woow seems really impressive, thanks for sharing that!
Is it possible to zoom out, in the graph, once we have zoom in?
I made some logs... But im trying to understand data...
So, here is a small log. Could you explain?
Im having serious problem with slip 1st to 2nd gears (SPORT and S-SPort) in WOT
This looks really interesting, so I reckon I'll have to give it a go :)
Edited to add: I've loaded up a log file and seeing some data in the analyser, but it only appears in the upper left pane. Any thoughts on what I've done wrong? Does the Evoscan file or xml log file need to be in a very specific order/format?
Further edit: Think I've sorted it now :)
What did you do to fix the log display?
1 - 19 of 19 Posts
