Explanation of tables
These explanations will most likely change / be revised as we understand each table more.
Last updated: 02.27.02
SST Limit Temperature
This dictates at which temperature the transmission will go into limp mode
SST Upshift - Lower Bound Fueling
This table is used while the car is shifting.
General idea is you only want this table a tad lower then your global fuel table so the car does not enrich during shifts.
It also functions as the fueling floor (fueling will only go as low as this table no matter what, even when not shifting)
SST Upshift - Lower Bound Timing
General idea is you only want this table a tad lower then your global ignition table so the car does not retard too much (and cause boost spikes) during shifts.
It also functions as the ignition timing floor (ignition timing will only go as low as this table no matter what, even when not shifting)
SST Upshift - Lower Bound Timing Retard Max
More info coming soon
SST Upshift - Lower Bound Timing Reduction vs Load/RPM
SST Clutch Pressure Ramp Up A/B/C
This table relates to the ramp up of clutch pressure at a given load.
This will not actually increase max pressure but it will let it hit the modes max pressure sooner. I currently view this as more of a "gain" control on clutch pressure. Be very careful with these tables. Too much increase from OEM values will create rev hang between gears.
SST Clutch Pressure - Unknown
This is currently Unknown.
What we do know, it is bundled with the A/B/C tables and unused for 2011+.
SST Clutch Pressure Ramp Up - Reduction vs Octane
This reduces the values in the CPRU A/B/C tables above based on what the current Octane % the ECU sees.
Do not confuse this with actual Octane level of the fuel you are using. Octane % is a rating the ECU sees depending on knock activity.
SST Clutch Pressure Ramp Up - Adjust Offset 2D
More info coming soon.
SST Clutch Pressure Ramp Up - Reduction vs CTS
This reduces the values in the CPRU A/B/C tables based on coolant temp.
SST Clutch Pressure Ramp Up - Reduction vs Alternator
This reduces the values in the CPRU A/B/C tables based on generator (alternator) voltage.
SST Throttle Requested Torque Map #1/2/3
These are Throttle Requested Torque Maps (DBW). #2 and #3 are based on coolant temps.
These have a direct relationship with the "SST Throttle Requested Torque Base", "SST Throttle Requested Torque Ramp Rate" , "SST Torque Limit" tables and possibly "Throttle Maps #1-5".
These relationships have a direct influence on how the SST cars drive.
We currently think this is the base value that is used for the DBW tables functions.
SST Throttle Requested Torque Subtractor Map
This reduces the values in the "SST Throttle Requested Torque" Maps depending on TPS and Boost Error Control status.
SST Throttle Requested Torque Subtractor Map Percent
The percentage of the above map that can be used, per RPM.
SST Throttle Requested Torque Ramp Rate (SST modes Normal/Sport/S-Sport)
Depending on SST Mode, these dictate the percentage of the Throttle Requested Torque Maps that are used by gear and speed.
Example: With OEM mapping, S-Sport will use 100% of the Throttle Requested Torque maps no matter the gear or speed.
SST Torque Limit #1/2/3/4
These are directly related with the "SST Throttle Requested Torque" maps and #2/3/4 are based on coolant temps.
Current tuning theory is that these need to be set the same or higher then the "SST Throttle Requested Torque" maps. If they are set lower the TCU will slip the clutches more on shifts. If they are set higher, the TCU will slip the clutches less. Fine tune these to your desired shift quality.
SST Torque Map #1/2/3/4
These are the old "Torque Limiter" maps we all turn off via 0xFFFF.
We recently found out these also have a direct code relationship with the SST. More info to come.
SST Torque Limit Reduction Table by RPM (CPRU_A)
This is a base for the values in "SST Clutch Pressure Ramp Up- Map A".
One of which is reducing the values in that table. We are still exploring exactly what this table does. We do know it works sort of like a "gain" control for the table it bases itself on. If you reduce these numbers too much, the car will start to not rev-match smoothly in lower gears.
SST Torque Limit Reduction Table by RPM (TqLimit_2_3)
This is a base for the values in "SST Torque Limit #2/3".
See "SST Torque Limit Reduction Table by RPM (CPRU_A)" for current explanation.
SST Torque Limit Reduction Table by RPM (TqLimit_4, CPRU_C)
This is a base for the values in "SST Torque Limit #4" and SST Clutch Pressure Ramp up - Map C".
SST Torque gearratio based adder
Not sure what this table does yet. More info coming soon
SST Max Requested Torque Limit
This is the ceiling (max) for Throttle Requested Torque
SST Torque Reduction On Exceedance
This reduces the values in the "SST Torque Map #1/2/3/4) depending on (we currently think) Requested Torque and something boost related.
SST Unknown #1/2/3/4/5/6/7/8/9
Currently do not know what these do.
