Twin Clutch SST:
MMC's new automated manual transmission employs dual clutches to realize power transmission efficiencies on a par with a normal manual gearbox while also allowing slick and swift shifting. Allowing drivers of all abilities to shift rapidly up and down through the gears, Twin Clutch SST delivers satisfying acceleration while also returning superior fuel mileage thanks to its high-efficiency power transmission mechanism. The new transmission also features three operating modes tailored to different situations: from around-town drivability to instant-response and follow-the-line sporty motoring on the open road.
*1, *2, *3, *4: see following pages for details
Twin Clutch SST (Sport Shift Transmission)
(1) The mechanism
Twin Clutch SST puts odd (1st, 3rd, 5th) and even (2nd, 4th and 6th) gears on separate input shafts, each connected to an individual clutch. With both clutches under precise system control, this arrangement allows lightening-fast, smooth and lag-free gear changes with no interruption in power delivery. Using clutches instead of a torque converter to transmit power makes the Twin Clutch SST simpler in structure and reduces power transmission losses for higher transmission efficiency that leads to improved fuel mileage.
(2)Drive modes
Twin Clutch SST allows the driver to switch between three shifting programs - Normal, Sport and S-Sport - to cover the full range of driving situations, from town use to sporty motoring on open roads.
a. Normal mode
For use around town and other normal driving situations, Normal mode scheduling uses relatively low-speed shift points to deliver unobtrusive shifting for maximum comfort together with optimum fuel economy.
b. Sport mode
For use when driving in the mountains or when engine braking is required, Sport mode scheduling uses higher shift points and quicker shifting to deliver instant throttle response that instills in the driver a closer man/machine relationship.
c. S-Sport mode
Compared with Sport mode, S-Sport mode scheduling keeps the engine turning at higher revs while allowing lightening-fast shifting.
What Twin Clutch-SST aims to achieve
Twin Clutch SST aims to combine the economy and dynamic driving of a manual transmission with the convenience of an automatic transmission.
Features
1.Slick, sporty gear changing with no clutch pedal.
2.Quick response and smooth shifting.
3.High power transmission efficiency and low fuel consumption.
System configuration
Twin clutch SST benefits
