1 - 3 of 3 Posts
Guys,
After selling my aftermarket wheels. I have been on my OEM wheels with KW V3s coilovers. The OEM offset is horrible on coilovers. So i looked into wheels spacer and found most guys are using a 25mm spacers. Checked out a bunch of them and since i already have KWs. I found that ST makes Wheel spacers. I gave them a call since i do have ARP studs in the front hubs and i wanted to make sure i ordered the right parts. I ended up with their front DZX 25mm spacers for the Front and 25mm AZX spacers for the rears. I did have to order there studs for the rear AZX and nuts to bole the spacer to the OE rear hub. i did for get to mention i did have to order there red center adapter which is for our OE center bore for the OEM wheels. This make the spacer almost like a hub centric so there is no play at all in the spacers are installed. they look great and made the car look a lot more aggressive.
Looks really good. I thought about spacers but will probably just get wheels down the road.
i am doing the same. Im going to get some decent wheels and tires to use while auto x and road racing. just wanted to add the spacers now on the OE wheels. Also no rubbing or anything. im not super dumped but have no issue at the ride height i am at.
1 - 3 of 3 Posts
