1 - 5 of 5 Posts
I'm currently running stage 2+ 93 Inj 93 GSR. I have Hard IC piping, DP back exhaust with 200 cel cat and Injen intake.
Just read a lot of hollywoods posts and trying to maybe do some self tuning as I have downloaded ATR and i'm VERY new to this. Only read for a few days (eyes hurt) on some of the gear heads posts. My boost seems to be low as target is 24-25 psi for this stage and i'm about 17-18 for most of the powerband. Power seems very "unsteady" from 4-6,000 rpm. Very on/off. I've attached 2 logs from 4th gear. Outside temp is at 87deg with high humidity. Any help would be great!
I have the pill out. I'm not sure of the boost leak. I have tightened all the ICP with t-bolt clamps until i thought they would break then tightened some more. Have not ran a boost leak test, I'm not the best mechanic you've ever seen, but can do some basics.
Discussion Starter #4
man i get the most help on this forum..............................jk
1 - 5 of 5 Posts
