1 - 4 of 4 Posts
STM Bellmouth Intake Pipe Kit
Application:
2008-2015 Evolution X
The STM Evo X Bellmouth Intake Pipe Kit is tig welded in-house of 3" lightweight aluminum and incorporates a 6" velocity stack to utilize the air space of the giant K&N filter. We include an aluminum intake heat shield, STM silicone coupler, clamps, brass fittings, block off's and vacuum hose for a clean install.
You will need to cut and re-route your blow off valve recirculation hose.
Features:
- Tig-Welded, Back Purged Aluminum
- Three Finish Options
- For Stock Turbo (2.75" Inlet) or Upgraded (3" Inlet)
- Stainless & Brass Hardware
- Heatshield
- CNC MAF Flange
- Barb Fittings with Optional Block Off's for Vacuum Lines
Options:
- Stock Turbo (2.75" Turbo Inlet)
- Upgraded Turbo (3" Turbo Inlet)
- Brushed Aluminum
- Polished Aluminum (+$30)
- Gloss Black Powdercoat (+$30)
Includes:
(1) 6" K&N Filter (RU-3100)
(1) STM Aluminum Pipe
(1) STM Aluminum Heatshield
(1) 1.75" Worm Clamp for BOV
(2) Worm Clamps for Coupler (2.75" & 3" for Stock Turbo or Two 3" for Upgraded)
(1) STM Silicone Coupler (2.75" to 3" Reducing for Stock Turbo or 3" for Upgraded)
(1) 1/4" NPT to 1/2" Barb 90° Brass Fitting (Used for valve cover vent tube)
(1) 1/4" NPT Block-Off Brass Fitting (Optional. Used when not venting valve cover)
(1) 1/8" NPT Barb Brass Fitting (Used for boost control return line)
(1) 1/8" NPT Block-Off Brass Fitting (Optional. Used when not returning boost control line)
(2) M8-1.25x20 Button-Head Stainless Allen Bolts (For mounting HeatShield to frame-rail)
(2) M8 Stainless Flat Washers (For HeatShield bolts)
(2) 10-32 x 5/8 Stainless Allen Bolts (For MAF Flange)
(1) One Foot 6mm Silicone Vacuum Hose (For relocating BOV)
If you have any questions or would like to order, Give us a call at 585-226-8226
Thank You!!!
-Ethan
www.stmtuned.com
Discussion Starter #2
Bump, Give me a call for this quality intake. Comes with everything you need to install it!
We have seen a gain of 60WHP with this intake and a tune!!!
-Ethan
Call 585-226-8226 to order the best intake on the market!!!
Uses a bellmouth inlet for optimum flow!
-Ethan
Discussion Starter #4
One of the lucky cars down in Florida just picked up 30hp from swapping to ours. It is definitely the best one on the market. Give us a call to place an order!
585-226-8226
www.stmtuned.com
1 - 4 of 4 Posts
