The only turbo mods I am aware of on the car are a blow off valve but it could be tuned of have MBC because it came with a boost gauge that peaks 25psi and has a vaccuum of -20 my problem is when I pin the throttle the turbo will spool up then at 6000rpm it will skip the car will shift hard with jolt and then I get a check engine light and the AWC screen turns yellow and turns traction control off. After I shut the car off and let it sit I can start it back up with no issues, I'm new to turbos so I'm wondering what my problem might be?
