The RC Engineering Evo X injectors come in 750cc version that are direct drop in injectors for your car. These injectors are capable of handling anything from a moderate setup to high horsepower builds. When you buy RC Engineering you know you are getting top quality parts and these are no different. The 750cc Evo X injectors are high impedance while the 1000cc injectors are Low Impedance and require Engine Management.
Flow Rate - CC's:
750 CC's / MIN @ 43.5 PSI
Flow Rate - LB's:
71 LBS / HR @ 43.5 PSI
Resistance:
12.5 Ohms @ 68 F
Voltage:
8-15 Volts, nominal 13.5 Volts
Amperage:
1.0 Amps
Pressure:
Min 30 PSIG / Max 70 PSIG
Set includes Denso Clip Connectors and Spacers.
SUPER SALE PRICE: $350
Flow Rate - CC's:
Flow Rate - LB's:
Resistance:
12.5 Ohms @ 68 F
Voltage:
Amperage:
1.0 Amps
Pressure:
