1 - 1 of 1 Posts
After removing the OEM tweeter you get this little tweeter bracket. It is very small,
So i had to alter it to fit Focal K2,I think most Aftermarket Tweeter will be Bigger then OEM, here the step it took
Cut off the clip on the braket that held the OEm tweeter, with a Knife
Place new Tweeter into the Tweeter pod
Put you modifed Braket on and screw them in. Done
Last thing, If you dont mind destorying your OEM Tweeter, Break The Harness off OEM Junk and you can get a pair of nice wiring harness for you Aftermarket Tweeters.
1 - 1 of 1 Posts
