Last week, I was trying to flash a new TCU version (the TCU from 2011+ MR) for a friend’s 2010 SST MR, using MUT-3, but it failed with no reason. I’ve done the same thing many times, even to my own car, and this is quite popular here in the local community of EVO. But this is the first time I’ve ever had a failure. The car is almost stock, including ECU.
The worse thing is, the failure seems to cause a disconnection between ECU and TCU. Now the engine can start, idel, rev … you can change the gear nob, but no gear would go it. In other words, the ECU is fine, I can read/write with ECUFlash, but the TCU is kinda bricked I believe.
From MUT-3, the whole CAN-Bus looks no problem at all (see attached image), but when using any OBD interface, like MUT-3 or OP2.0+ EvoScan, it just keeps saying something like 'communication to SST control unit failed', or like ‘CAN connection time out’, or like ‘TC-SST time out’, etc. … You can clear these DTCs, but they will turn up again in seconds. This seems really weird to me, since if the CAN-Bus is all fine, there is no reason why the connection to the TCU cannot be established. But the symptom here seems to me that the CAN bus connection of the TC-SST (or the ASC) is totally down or blocked.
We’ve tried many ways, like upgrading MUT-3 to the latest version, cut-out the battery for 6hrs, etc., reflashing the ECU, or try to reflash the TCU again (of course it failed, again) But none of those would work.
The Mitsu dealer says that what they can do now is to just replace the whole SST. But I am thinking that it must be a software problem and can be fixed via software.
I know how to deal with a bricked ECU, but have never seen any discussion on bricked TCU after I’ve done lots of search on evom and evoxforum. I've also asked many masters here, but no one seems to have come across this issue before.
So ... anyone has any idea? Thanks heaps in advance!
-Bin
-Bin
