I'm currently installing my AEM water/meth kit with the Aquamist DDS3 failsafe. I have the DDS3v8 module. I'm going to have SSP use Tephra to switch maps with the failsafe. Does anyone know how to wire the DDS3 module to the ECU? I've read that the ECU needs 5 volts from the failsafe. I don't think the DDS3v8 outputs 5v. I've read somewhere that some units will require a resistor and/or relay, but no instructions on which components and how to wire them. Also, which pin(s) do I go to on the ECU? I think I'm supposed to use either pin 11 or pin 12 on the DDS3 unit. This is all so confusing! I would message Tephra, but I don't want to bother him with it. I hear he's pretty busy these days.
Any help would be much appreciated.
