1 - 19 of 19 Posts
IM hitting SES in 4-5 just like passing some one. Will this fix me up? And where do I place the
<table name="DTC P1238 Disable 0x0384 -> 0xFFFF" category="Misc" address="631ae" type="1D" scaling="Hex16"/>
<table name="DTC P1241 Disable 0x03E8 -> 0xFFFF" category="Misc" address="631a4" type="1D" scaling="Hex16"/>
<table name="DTC P1235 Disable 0x0026 -> 0xFFFF" category="Misc" address="549b2" type="1D" scaling="Hex16"/>
<table name="DTC P1233 Disable 0x0028 -> 0xFFFF" category="Misc" address="549ae" type="1D" scaling="Hex16"/>
<table name="DTC P1234 Disable 0x0028 -> 0xFFFF" category="Misc" address="549b0" type="1D" scaling="Hex16"/>
Is it just like enable mode23? Or harder? Im still new to this.
It works the same way as mode23. Just copy and paste the code into your xml file and start ECUflash. You should see the new tables. Change the tables content to 0xFFFF and save the rom, then flash your ECU. If your getting any of these CELs, then that should stop.
Will this work on 52680018? If so whats the code? Just says 53680015 -> 52680020 mine not in there. Thanks guys!
I dont mean to be stupid but im looking at the id numbers and its say 53680015 -> 52680020. Mine is 52680018 did they mean 52680015 -> 52680020 Do see what I mean?
Forgot to add this it works great!!! I VTA stock BOV and have no code no problems.
1 - 19 of 19 Posts
